- Sep 24, 2017
- 250
- 6,437
And a chisel set too, 2800BPM , $35 and the chisel set was $25. I can see this coming in handy.
As a retired 50+year body repair tech,from experience,I say NEVER use this air chisel without wearings gloves and ear protection! Your hands and ears will thank you!Make sure you learn quickly not to have your hand near the spring when using. Band Aids should be handy the first dozen times you use it, plus a good pair of gloves.
And don't over oil it
Two drops once a week or so will be fine as the oil blows out all over the spring which gets slippery and cuts your fingers when changing tips
