got a stihl 025 45cc chainsaw , someone asked if I try to get it running again, compression 110, looks to have new carb, have spark at the plug , took carb off and clean it , try starting it not a pop, even tried start fluid and nothing, thanks
When cleaning the carb did you set the lever needle?
Problems with non starts can be the carb not sealing due to the needle lever.
Have you tried dopping the cylinder with fuel?
