Need help with my SV600 crankcase
dlemoncelli
Hello,
My crankcase had a crack, so I bought a used one. All numbers match on both cases. There is one issue that I found, and I've searched online for a fix, but came up with nothing. On my cracked case....on the bottom left hand side there is a pin which had an arm that hooks to the bottom of the balancer. The case that I bought has no pin. I can't figure out how to remove that pin and transfer it to the new case. If it's part of the case cast...what do I do about attaching that arm? Like I said all numbers match on both cases. Any advise would be greatly appreciated.
attachment.php
attachment.php
Scrubcadet10
Moderator
Staff member
Does the pin look like this?
