NEED HELP WITH MODEL NUMBER AND YEAR OF MY YARD MAN TRACTOR
Short Bus 11
  • / NEED HELP WITH MODEL NUMBER AND YEAR OF MY YARD MAN TRACTOR
I have a Yard Man MTD garden tractor, not sure what year it is and the model number. I cannot find any numbers on this tractor except on the engine. It is a Yard Man 22hp. hydrostatic automatic with hydraulic deck lift, and hydraulic 3 point hitch, and front shaft driven pto. :frown:
BlazNT
Maybe 1996 MTD Yardman 999
gfp55
Maybe a Yard-Man 995 - 999 made by MTD. White outdoor has tractors like that also made by MTD, same tractor just different colors.
upnorth
look underneath seat for model and serial number
Fish
If it is not under the seat, look under all of that chit bolted onto the rear, that is likely where the tag is....
Yardman999
Old thread, but may be helpful to others:
Looks a lot like my 1995 Yardman Model 999. They were made for MTD by Kwik-Way, a.k.a. KW Manufacturing, of South Dakota, better known back then for their forklifts, etc. Tractor Supply Company (TSC) was one seller of the 999 and its accessories.
Mine's still going fairly strong (2019)!
Fish
Wow, 5 years ago!
milda
I would like to find out the year my yardman model N91871 lawnmower was made.
Model and serial number should be under the seat if still readable Also can check the model number information on the engine. If briggs engine the code part of the model number is the year, month, day. Kohler uses the first two digits of the serial, which are not the year directly but can be used to find year.
Under the seat is the model and serial numbers tag.
Right now the model posted is coming as the tail number of the following aircraft.
N91871, SCHWEIZER SGS 1-23, CT-226, Glider
