Need help buying a replacement battery for a Yard Machine Riding Mower
rkode
  • / Need help buying a replacement battery for a Yard Machine Riding Mower
I could sure use some help.
I own a Yard Machine Riding mower (by MTD) and I need a new battery.
(Please see attached file)
I would love to pick one up at my local tractor store or even a local Walmart.
But, I'm confused as to how to know which battery to buy.
I found the following on an MTD parts site.
The site states:
  • Fits most riding lawn mowers and Residential Zero Turn (RZT) Mowers
  • For Troy-Bilt, Cub Cadet, MTD, Yard Machines, Bolens, White Outdoor, Huskee, Murray, Craftsman and Yard-Man
But, this site doesn't state the "U" size or physical dimensions.
Hight, width, depth.
So, I was wondering ........
Dose anyone have a Troy-Bilt, Cub Cadet, MTD, Yard Machines, Bolens, White Outdoor, Huskee, Murray, Craftsman or Yard-Man for which they have purchased a battery ?
If so, what did you buy and where did you buy it ?
Thanks in advance for any replies
Ray in Wisconsin
Maybe this will help, For the most part, all riding lawn mower batteries are the same size and voltage. In almost all instances, when you are replacing the battery you will need a 12-volt battery that is 7" to 8" long, 5" to 6" wide and 6" to 7" high -- the battery does not have to be snug in the compartment. I recommend a battery with at least 300 CCA. Should be able to find at the stores you listed, just make sure the +&- terminals are in the same location.
Take a picture of yours. Go to what ever store you like. Show them your picture. Tell them you want one of those.
