Need help, Bolt/nut holding Deck on Husqvarna Z254F
MagnusA
  • / Need help, Bolt/nut holding Deck on Husqvarna Z254F
Hi,
Recently half my deck fell to the ground while mowing. Stopping and looking under the mower I found that this one bolt and nut that is supposed to hold up the deck to the frame has gone missing. See attached picture. The green circles represents where the bolt is supposed to be.
I tried to look at the drawings for spare parts but I cant figure out what is supposed to be here.
Can someone advice me the part numbers for the bolt and nut and even better if one could tell me the sizes and I can just go to any hardware store.
Cheers,
Magnus
The shoulder screw (bolt) PN 532 19 65-39 is not something any hardware would have. Your mower repair shop should have or at least can get it for you. Now the 5/16-18 Hex Flange Nut they should have but I would use a serrated version which basically a built in lock washer..
MagnusA
Thank you so much. Do you have the part number for the 5/16-18 Hex Flange Nut ?
MParr
MagnusA
OK, thank you, tried to find the original part number but was not to be found.
The Husqvarna PN for the nut is 873 90 05-00.
