Need Help Adjusting Carbeurator Screws
jakesmurray
Purchased brand new carb for my Murray 12.5 hp, Briggs and Stratton engine. It has a slight popping surge at the run setting on the throttle. Other than that, it runs fine. It doesn't do it at idle, or under load. Can someone please tell me how to adjust the two screws on the carbeurator?
KennyV
Hello jake... & Welcome to the LMF...
What carb is it?.. :smile:KennyV
jakesmurray
Thanks! It is a Walbro 498027
KennyV
Is there a needle set screw in the main jet, bottom of the float bowl, or is it just a bolt?
:smile:KennyV
jakesmurray
It is just a bolt and it is not adjustable.
