1st time: I was cutting one strip at 3 in’s High along my gravel driveway, then the blades & belt stopped turning. The belt is only 2 months old,
2nd time: The next day all was good until I tried to engage blades 2nd time After cutting for about 15 minutes, I had to stop for a break and move toys off the grass. I shut it down, but then it happened again no longer engaging when I was ready to mow more. Prior to this I noticed when I engaged the blades it was different, The sound was less, the engaging of the blades was slower But they did engage. Is there an adjustment or is the clutch going out?
