My Troy-built lawn mower has a bent shaft that the blade mounts.
GaRock
  • / My Troy-built lawn mower has a bent shaft that the blade mounts.
The mower is 4 years old and a B&S motor # 09P602-0076-F1. I have found only one motor from either B&S Troy-Built that has a replacement. The price is $ 360.00 plus $50.00 delivered. I can go back to Home De Pot and get a 2022 model brand new for 299.00 plus taxes. I found an engine, B&S # 09602*0077-F1 for $89/00 plus shipping. I have not found any info on different motors that I can use in place of the original. The bent shaft cost $122.00 plus shipping. I am not a mechanical person when taking a motor apart and putting back together. Any help or suggestions, I would appreciate it very much! Frank.
Both 09P602-0077-F1 and 09P602-0076-F1 supposedly have the same as both supersedes to the 093J02-0086-F1
And yes it is quite to be able replace a walk behind engine with a complete new mower as Briggs sells the engines in volume to the mower manufacture dirt cheap.
sgkent
if you are not mechanically inclined, sell the old mower for parts, and buy a new one. Then walk the property and get rid of the object that bent the crankshaft, or at least flag it so you don't do it again.
