7394
- Sep 5, 2014
- 84
- 4,710
After last mow I did the oil & filter change.
Then days later put my Z up on the wheel dollys I park on, so I can slide it out when I want to tinker on it.
Today removed the blades & soaked them in a drain pan with water. 1/2 hour later I wiped the blades clean. No fuss no muss, the water does the work of softening the grass build up. Cleaned the underside of the deck... When I get back to it I'll put on the spare blades. Then later sharpen the OE blades & balance.
