Murray twin engine electrical
CubLover
I hooked up my solinoid and the wires startedto smoke. I havent tried to fix it yet. But what could i have messed up? I prolly hooked it back wards
Hope this will help. On your solenoid you will have either 3 or 4 terminals, 2 large and 1 or 2 small. Onto one large terminal you will attach the large cable coming from the battery and one small wiring going to the B terminal on the key switch. On the other large terminal you will attach the large wire going to the starter. On one small terminal you will attach the small wiring coming from the S terminal on the key switch. If you have a second small terminal, it will have a small wire which will go to ground.
motoman
What went wrong may be you hooked up a "hot wire" to ground and made an electric toaster wire. Follow above routing should cure. Replace or splice proper gauge wire where burned.
justice2010beau
i am having the same issue with a murray 405000x8g select when i attach from solenoid to red wire it sparks why?
justice2010beau
I have the same issue when I attach to the red hot wire and make a ecticric toaster wire it sparks why?
Which wires started to smoke ?
You should have 4 or 5 wires depending upon what type you have .
the 2 heavy cables go on top and it does not matter which way they are hooked up
After that there should be a power feed to the mower wire that goes on the battery wire and either 1 trigger wire that goes on the tab on the base or 2 trigger wires if the base is isolated from the trigger coils.
Some of the single trigge r wires also have a ground strap that goes onto one of the mounting bolts to ground the solenoid body.
If you accidentially hook that wire to the battery wire then you have made a dead short
If you accidentially hooked it up to the starter terminal then it will be a dead short when ever you try & crank the engine .
justice2010beau
I'm just going to give you a little bit of background information I bought a Murray 40 inch select model number 405-000x8g used in January and when I first got it it would not want to start every single time sometimes I would have to Rock It and then I ran over something in the yard a cement Boulder after that a whining screeching noise would come from underneath my feet so I replaced the motion drive belt and then it just wouldn't start or it would click I knew there was a short somewhere because every time I push the clutch in I would hear sparking so I wanted to remove all the safety switches anyways so I removed all the doids and all of the wiring I only use the stuff that I needed so I did the solenoid the way you said in your reply I put the battery cabled to one big terminal the starter cable to the other terminal and then I have to little terminals I put one wire going to the ignition and then the other wire on the big terminal going to the ignition I have a black and a red wire coming from the Magneto or coming from the alternator I'm assuming the red one is the one that recharges the battery a wire is going from the red wire to the big terminal when I do it it just clicks it's not the solenoid it's not the starter I've replaced both of them and I've replaced the battery is there some kind of ground that I'm missing or should I connect the red and the black wires together and then run them to the solenoid I thought the black one went to the headlights though thank you for your help
