Martin Collins
- Oct 7, 2021
- 2
- 2
Hi All,
I recently acquired an old Murray 3hp single stage snowblower (Model No: G20300000) and I decided to tear down the carb to give it a good clean in preparation for the winter. Upon putting everything back together and starting the engine I realized that the engine was running way too fast. Upon further investigation, I discovered a white plastic lever that is connected to the (spring loaded butterfly valve located on the) top of the carb by a small thin connecting rod - see plasticlever.jpg attached.
By adjusting this lever, I can control the RPM's of the engine. Now for the life of me I cannot figure out if or how the plastic lever is meant to be adjusted or if it is meant to lean against anything. The lever is actually hidden by the engine top cover (see below pic) so that is why I did not notice it when I was removing the carb for cleaning - see engine cover.jpg attached.
There is nothing inside this top cover for the lever to attach to or rest against nor is there any other parts of the mechanics of the snowblower that I can see it that the lever connects to. Furthermore, there are no holes on the plastic level itself other than the point where the small thin connecting rod attaches to the top of the carb.
Does anyone have any idea what I am supposed to do with that white plastic lever?
Leaving it as it is is no good because the resting position of the level results in the butterfly valve being open which means that the engine is running at maximum RPM's. At this point I am tempted to just ziptie the lever to hold it in a certain position at a point where the engine RPM's are comfortable but this seems like such an insane kluge to me and is driving me nuts how I can't figure out what on earth I am supposed to do with that white plastic lever.
Any help would be most appreciated!
Thanks,
Martin
Thanks,
Martin
