thank you will have a look tomorrowIn all of that grease or perhaps still inside the diff will be a spring clip
Either a C , E or plain wireclip.
Clean up the diff end of the axel and you will see the slot
If it is square at the bottom then you have lost the E or C clip
If it is round on the bottom it is a plain wire clip.
