MTD 38 in shift on the go
steveo2155
Any idea where to find a plastic chute and mulch kit for this? Model number 136L673F382. Also the shift lever that you use to change speeds feels loose and sometimes bounces into next speed if I hit a bump. Is there a way to fix this and tighten up?
logert gogert
Hello, welcome to the forum.
I have found A chute for you, don't know which company you wanna get it from, but the cheapest one i found was on Walmart's website:
And there is also a chute i found on the genuine MTD website, but its more expensive:
Also found a mulching kit, and a pair of mulching blades, assuming you don't have a pair of blades already:
Blades:
Mulching kit:
Fish
The "shift lever" just changes tension on the belt system, so you will have to look for sloppiness, maybe a spring that pulls it tight into the notches. Put up a pic of what you have.
