I have a MS251 that I bought several years ago that has been running great all along, until about a month ago, it was submerged in a flood for about 15 minutes. The next morning, as soon as we discovered that there was a flood, I cleaned it up, dried everything out, WD40'd the cylinder (There was water inside) and let it sit wide open for several days. After putting it back together, it runs the same as it did before the flood, but the problem I have is it's not oiling the bar properly now. I've double-cleaned the bar, the oil holes are clear, the track is clear, and when I run the saw with the bar off, I do get a slight dribble of oil from the oiling hole, and running it with the bar and chain to see if I get 'splatter' on some cardboard, there does appear to be a small amount, but it's not like it was in the past, and I have used a tank of fuel and the bar oil is not even 1/4 used.
Does anyone have any thoughts as to why it was fine last time I used it before it was flooded, but now it's not oiling right afterwards? Could being submerged have caused some issue with the oiling system, or might this issue not be related to the flooding at all and just a crazy coincidence?
