I have a Toro 124k02-0110-b1 mower.
It has been working fine all season. There has been a small fuel leak which only occurs while running.
Anyways, suddenly, it wont start. When I pull, it spins, but the engine doesn't turn over and does not seem like it is trying. Plenty of fuel in the tank. It worked last week so I assume the fuel is good. I checked and changed the spark plug, I can visibly see the spark. I also changed the air filter. I removed the screw/bowl of the carburetor. There is fuel at the bottom. I can see through the hole in the screw but clean it out anyways so the hole is bigger now.
We have fuel, air, spark so I would think it should start.
I am not exactly sure which direction the fuel flows in the carburetor. If there is fuel in the bowl, does it mean there is fuel/air getting to the cylinder?
I'd appreciate any recommendations
