Philipshari
- Aug 23, 2020
- 2
- 2
Hi. I own a Honda HRX217 HMA mower I purchased in 2004. The mower has about 7 years active life used and went thru a long period of inactivity due to outsourcing mowing responsibilities I recently sent it to a repair shop to prepare using it. The carburetor, spark plug and air filter were replaced and the gas tank was cleaned.. The mower would not stay running The gas source is the same as with my Zero turn which runs fine. I sent it back to the repair shop and replaced the ignition system coil. The mower runs for 10 minutes then the engine starts to miss and then shuts down as if it ran out if gas. It will not restart until about 15 minutes go by and then the cycle repeats itself.. After replacing the carb, spark plug, air filter and then the ignition coil, whats left? I've had to the repair shop 3 times now with an outlay of 140 bucks. This was an expensive mower (battery starter)and I'd like to keep it but is it worth it? What else is left to investigate?
Thanks for your input!
