MOWER WILL NOT START!
popsthecook
THE MOWER ( MODEL YTH22V46) WILL NOT START WHEN I EVEN JUMP THE SOLENOID, THE ENGINE TURNS BUT WILL NOT START!
Chevychopper
Have you checked the safety switches?
Checked the throttle linkage...
Two very common issues for one not to start.
First when you jump the solenoid do you have the key in to run position? Second have you checked the fuel solenoid? Third when you say it will not start, do you mean nothing happens or engine spins but no firing in the cylinders?
csmdew
Just found out on my mower, which had same problem, that the nut holding brake rocker on was loose and not making contact with safety plunger, tighten nut up and all is good.
