I had an issue with my mower searching like in this video Troy Built Pony 17 HP Briggs & Stratton Governor/Idle Issues - YouTube I ordered a carb kit and replaces all the gaskets, needle, pins, springs and cleaned the carb with Carb cleaner. I was unable to change the welch plug due to not having anything to remove the old one (at that time). I made sure to spray out every porthole I could see. While I was at it, I replaced the spark plug and oil, checked the rocker arms (shaft was loose earlier in the year) and because I thought I smelled gas in the oil, added a fuel shut off valve and new fuel filter. The mower now cranks and runs great at low and mid throttle, but when I put it in rabbit, it dies. Once it dies, it is hard to crank back up, but once I do it does the same, dies at full throttle. I recenlt switched to non ethonl gas.
Any suggestions would be appreciated, I am trying to get this running before the Lawn Mower Parade this Saturday, yes I live in a small town
2011 Troy-Bilt Pony
Briggs and Statton 31c707-3346-g6 engine with a Nikki Carb (795366)
2011 Troy-Bilt Pony
