YawningAngel
- Mar 26, 2020
- 1
- 2
Hi all!
I have a Mountfield SP414, equipped with an RS100 motor - a generic 100cc Honda-clone with an auto-throttle & no choke.
It starts easily and idles smoothly, but when I start cutting grass it stalls within about 10'. It seems as if the auto-throttle is not reacting to the load (due to grass cutting), so in effect, it it truing to cut at a constant idle...and not surprisingly stalling fairly quickly.
I have done all the usual checks....fresh fuel, clean air filter and even a full strip down or the card (incl an hour in a hot ultrasonic cleaner followed by a blow through all orifices with an air line)....all to no avail.
When running, if I manually actuate the auto-throttle, the engine revs up well...it just doesn't seem to want to do so itself...
any ideas...?
cheers
Paul
any ideas...?
cheers
Paul
