jekjr
- Jan 3, 2013
- 271
- 1,967
The Kubota ZD 326 has the ability to raise it's self for blade change and other work under the deck. To raise the mower you raise a cover on the very front of the mower and remove two pins. You then turn the casters to a position where holes line up and insert the pins in the holes. Then you pull a handle out of a bracket and fold it around and turn a crank and within a few seconds the mower is raised by pivoting the entire front end so that the mower is standing on one wheel with the other sticking almost straight up. Does any other zero turns have some option similar to this to raise them for blade changes?
