Motor pulley question
Matt370
I have a Craftsman YT3000 that has a 21hp single cylinder that locked up. I picked up a same frame Husqvarna with the 20hp vtwin but the shaft size is larger and it has an electric blade clutch. Does anyone know part numbers for an 1 1/8" shaft double pulley?
Scrubcadet10
Moderator
Staff member
Will need the model numbers of the mower engine and the mower... model tags of the mower are usually stuck on the bottom of the seat.
engine model numbers will be stamped into the valve cover.
Matt370
I just put the drive pulley and blade clutch back on the motor. Will have to wire a toggle switch for the clutch. I don't think they really make a double pulley for the 1 1/8" shaft size. This site was telling me my picture files were too large to upload.
