Hi all!
My girlfriend and I purchased a Craftsman 21" push mower a couple of months back. After going through the first tank, we have had nothing but trouble from the mower.
At first I thought bad gas. Drained the tank and re-filled with fresh gas and things were ok. But the following tank had the same problems. Drained it again, but it still would not start. Thought I may have over-filled the tank, so I went to drain it again. Just to make sure the gas was good I pulled the starter a few times and the mower started up and ran like a champ. this was with the gas line detached at the tank and the gas cap off as well. So I re-filled (made sure not to over fill) and the mower started up and ran fine. Now, I tried to start the mower today and the same symptoms are present. Mower started for a few seconds then dies, wont start back up. Tried draining the tank again--fuel line off with cap off and the mower started back up and ran. I have even tried starting the mower with the cap off to see if the cap was gummed up, but it would not start. The mower only seems to start after the fuel line has been disconnected from the fuel tank. Any ideas as to what the hell is gong on? If the fuel line was clogged, wouldn't the mower still not run even if it was disconnected from the fuel tank? Its like the mower cant get enough air with the fuel line connected. This mower was bought brand new off the sales floor. Thanks for any suggestions.
