Johnny Reb
- Feb 2, 2021
- 1
- 2
Hello all. Newbie here. Has anyone ever run into a Kawasaki FR691V that was torn down for high oil consumption and found it to be missing one of the oil ring rails??? I bought this machine used from a very disgruntled Gravely customer. He states that he used the machine less than two years before it began consuming two quarts of oil to cut his yard, not very large yard either! He stated that the dealer refused to do warranty work on the machine, despite his keeping up regular scheduled maintenance at the dealership. I bought it cheap. It has an awesome amount of power, but he was right it drinks oil and lays down a smoke screen. Upon tearing down the engine I saw no rounded off bolts or other signs of previous repair attempts. What I did find was one of the oil ring rails completely missing??? Could this be a factory goof? The other ring end gap was nearly ,250 inch. Yes it has eaten much dust as these machines do because of the cheap air filtration system they have. Bore , cam, and crank are just within spec and valves check out great. I'll ring it and see what happens. Just curious if anyone else has seen this?
