Just got a new Maverick KAW 60" cut machine. It has the manual foot pedal to raise/lower the cutting deck. How do I lock the deck in the 'up' position? When I tested the mower, I seem to remember that it would lock if you depressed the foot control all the way, the depress again to release to the selected cutting height. Is there some trick here I am missing? Or does in NOT lock in the up position. Thanks in advance.
Pigdoc
Pigdoc
