I have just purchased a masport 550 and as I cut my grass weekly and it’s rye I like to cut it low.
It’s almost as if the blades are set too high inside the mower, on the ideal blade height setting the body drags along the ground (on the grass not if you push it on concrete)
On the next height setting the body clears the ground but doesn’t cut low enough.
Does anyone k ow if it’s possible to lower the blades inside the body?
