isiman1
- Apr 3, 2021
- 1
- 2
I have an older John Deere l118, I think it's from 2008. I took off the mower deck and I want to make it faster so I can drive around my yard for fun since we do not mow our own lawn anymore. I bought a 4 1/2" pulley and removed the stock one on the crankshaft and replaced it. It did go faster, but it was only a little noticeable. So I went on Amazon and bought a 6" pulley. Since I put the 6" pulley on the crankshaft I needed a larger belt since it is much larger than the stock pulley so I cant use the stock belt. I went to Tractor Supply and got a 1/2" x 92" v belt and the mower drove and it goes much faster when I set the rpm to the middle of what I can set it to, but if I open it up and set the rpm lever to the highest (rabbit) setting it doesn't go faster if anything it goes a little slower than what it was doing in the middle rpm range. Any thoughts as to why it won't go any faster? Is it the hydrostatic transmission that's limiting me, is the belt too tight or not the right size or something?
