I bought this mower used/refurbished a few years ago. After I changed this oil this spring, I had to try to start it 3 or 4 times before it finally turned on and it worked fine. I even started mowing the lawn, then about 30 minutes in I saw a neighbor next door and shut it off to talk to him. Then, after I was done, i tried starting it afterwards and it wouldn't. Sometimes it clicks when i try to start it but the engine never even gets going (it doesn't even make that noise when you are starting anything gas powered before the engine fully turns on).
I thought the battery was perhaps the cultprit because i've had issues with it before. I took it to Battery Mart and they said it's fine it just needs to get charged. So I left it there overnight, and when I reinstalled the battery it still doesn't start...
What is next on the check list? If I can't fix this thing I swear I'm never gonna buy a riding mower again, these things are NOT worth the trouble...
