I just bought this mower.
When I let out the brake/clutch in any gear but first it does a wheelie for about 3 feet.
Is there anything I should check/look out for?
I have seen a lot of the newer mowers with the brake set too tight, and when you let out on the clutch brake, it is like reving up the engine on a vehicle and dumping the clutch.
I would watch out for small children and dogs. will it still do that if you have the blade engaged? yes I would also check brakes maybe adjusted to tight or just getting hung up
