I am new to the forum. I have a LT1000. Model 917.272066. All worked fine up to today. I started the mower, engaged the blade, went to disengage the blade and it was like some turned the key off. Now I have nothing. Battery is fine, motor turns over by jumping solenoid, replaced ignition switch, replaced OP Relays and checked all interlock switches with continuity check. Still nothing at the key. I noticed that the fuse was blown. I put in a new fuse, turn key to head light position (1st position) and fuse blows. Disconnect head lights and fuse still blows. Disconnect the electrical connector going to the motor and fuse does not blow.
Any help is greatly appreciated. Thanks
