Looking for parts for my DGT 6000 (917.276120)
Mothman
Hi Folks,
The steering wheel currently mounted on my mower is not for/from this model. It's thin, loose and overall ugly.
Have been looking on amazon and ebay for a replacement but it's hard to get all the right pieces together. I need:
159944X428 - Steering wheel
159945 - Steering wheel adapter
19182411 - Washer
73940800 - Toplock nut
159946X428 - Steering wheel insert
So basically everything that mounts on top of the steering shaft :)
Does anyone here have the whole steering wheel assembly available for sale? Or know a good place to buy all the needed parts?
Thanks!
Jay
mechanic mark
Mothman
917.276120
Did they make multiple models DGT 6000? I believe this is a 2004 but can't verify. Just what I was told when I got this thing :)
Scrubcadet10
Moderator
Staff member
steering wheel and adapter https://www.ebay.com/itm/Craftsman-...980947&hash=item2657f8c442:g:XQwAAOSwU7lfsDxE
for different model but same part numbers.
Washer https://www.ebay.com/itm/New-AYP-Cr...310863&hash=item3b52664613:g:Li8AAOSw~mxfubRd
dimensions are given for the washer, so you might can go to a hardware store and get it. 9/16" I.D. with a 1.5" Outer diameter
Lock nut https://www.ebay.com/itm/New-AYP-Cr...617523&hash=item3db015ae51:g:jgkAAOSwJxVfuXL-
appears the thread count is listed as 1/2-20 .. Hillman makes some lock nuts that are 1/2-20 sold at home depot or just google search 1/2-20 lock nut.
The steering wheel insert is superseded to a new part number and appears available https://www.jackssmallengines.com/jacks-parts-lookup/part/ayp/532172092
Hi Folks,
159944X428 - Steering wheel 532166627 NLA
159945 - Steering wheel adapter 532159945
19182411 - Washer 819182411
73940800 - Toplock nut 873840800
159946X428 - Steering wheel insert 532172092
Thanks!
Jay
I updated your part numbers to the current superceded numbers. the steering wheel is coming back as No Longer Available.
Mothman
Thanks for the comments!
Looks like ebay is the way to go then.
