D
Deleted member 97405
Guest
Years ago, Briggs made a seal protector set (#19356) that consisted of various sizes of thin plastic tubes that you could slip over a shaft to install an oil seal. Its purpose was to protect the seal if the shaft was a little rusty beyond the seal surface. Without this tool, you'd have to sand the surface of the shaft smoothe all the way to the seal location. This tool allowed the tech to install the seal without having to dress up the rest of the shaft as well. It's a huge timesaver and makes installing seals onto older machines a breeze. This kit unfortunately was discontinued a while ago, and I can't seem to find one anywhere. Does any retired tech out there have a kit they'd be willing to sell or know if there is anything equivalent out there? Thanks!
