(Little Wonder blower) 8HP B&S throttle linkage spring
samt hoyce
  • / (Little Wonder blower) 8HP B&S throttle linkage spring
I have an 1988 Little Wonder blower with the 8hp Briggs and I had the carb off and apart for cleaning. At the same time I took the throttle linkage apart for better access to clean and whatnot. Everything is set to go back except I didnt take much notice of how the 1" long spring reconnects. Is anyone familiar with this linkage and can advise on the proper placement and connection. Thanks very much.
Post engine numbers and we’ll be able to help.
samt hoyce
Ok thanks, the info I have is that its an 8hp Briggs and Stratton I/C Cast Iron Bore (from the label).
On the cover its marked,
Model: 195422
Type: 0722 01
Code: 88111510
Hopefully this is useful. Thanks again.
samt hoyce
Wow thank you so much! I'd spent a long time searching online to find a simple diagram of what I have and nothing came up. Page 154 from your second link has exactly what I need. Very helpful and lesson learned. Cheers!
Once a year I get lucky. Now I can be Rip VanWinkel and nap the rest of the year. Thank you for letting us know.
