Light Bar for 3160 Xcaliber 2016 model
eb32310
Want to install LED light bar on rollbar. The bigger, the better
but not sure how many watt light to use. Only lights my dealer
has are 50 watt set. Been told can’t exceed 8 amps or could
damage electrical system. Anyone know what is available and
how powerful I can go? Thanks!
jeffdoss
I'm looking for similar advise. What did you end up using?
heavy_kevie
8 Amps at 12V is 96 watt so 50 watt light bar won't be an issue. 50 Watt is 4.1666 Amp at 12 Volt.
