Lifetime deck warranty
Status
Not open for further replies.
Kenneth Brock
I have a TS 348 LAWN Tractor purchased new in Aug 2019. I purchased it because of a lifetime warranty on the welded debt. O only use it for my residence. The deck came apart while taking up leaves and Husqvarna will not honor warranty.
What do you mean by came apart. Did a weld break or did something else happen. A picture may help us to determine the next approach. May have to do some resizing to post here, or use a photo hosting site with the link posted here.
Lifetime warranty = warranted till it breaks when it's life is over so the warranty expires .
They are a con & always have been
That a new one. A welded debt. So I assume you are welded permanently to you debit which every loan shark wants you to be.
If referring to the deck it only cover the housing and not the spindles, idler pulleys, or deck belt.
Status
