Leaking Hydro?
retfr8flyr
Hey guys, I have an Raptor SD 48" with the 2800 Hydro's, out of warranty. I just noticed today the right hydro is leaking oil. Is this usually an expensive repair, or is it most likely a seal or something. It's hard to see but it appears to be leaking from the bottom area of the hydro. I'm too old to try and fix it myself, so I will have to take it in for service.
Could possibly be leaking from the charge pump cover, which Hydrogear had issues with warpage and there is a complete cover replacement kit if that is what is causing issues. You will need to replace the oil after removing the cover since all the oil will drain our anyway.
