Hello All:
My 5239 mower surges or hunts during use. It starts on the first pull but acts as if it is starving for fuel. Adjusting the needle makes no difference as I can turn the needle until it hits the bottom of the engine and no change! I just rebuilt the carb so it is very clean. The surging is why I rebuilt the carb!
Should I open the main jet by drilling it to a larger diameter? If so, how much? If this is not the fix, what else should I consider? The fuel is 16-1 and is fresh. Could fuel with excessive oil cause this problem? It really produces a large amount of smoke!
Perhaps it is not a fuel problem. Perhaps the governor is sticking or is loose or...
Suggestions and or comments?
Stay well,
Franchi
Stay well,
Franchi
