MartinOtterbourne
- Oct 15, 2021
- 1
- 1
Hoping to get some helpful suggestions - lawnmower runs until you start to mow and then it stutters and dies. After which it won’t start until about 10 minutes after which the cycle repeats .
There is fuel and a new spark plug .
The make is an Einhell GCPM 40 S P it’s about 1 year ago old . Local repairers won’t touch it as parts are hard to come by although lots of people seem to sell them.
I’ve taken off the carb and squirted it with cleaner . It all looks very clean anyway. What I cant figure out is how to remove the main jet as it doesn’t seem to have a screw to remove it as shown on many you tube videos .
Reassembly still the same issue with stopping
So if this is a carb issue then I need to clean the main jet ? But I cant see how it can be removed with no screw. Every you tube video I watch has a slotted screwdriver slot.
Or am I sniffing up the wrong tree?
