Brianp48093
- Oct 17, 2015
- 2
- 11
Good morning everyone.
***I'm including my Dropbox link with pictures***
https://www.dropbox.com/sh/sv9aah4yelw4psc/AAB-oDUOcneAqMJnMZKKaXK7a?dl=0
Need some input! I have a Lawnboy engine F series, (I think it's an F). The number stamped on the engine below the spark plug is 681430-D3.
I'm pretty sure the model is a 1978/79 7268 but I'm not positive. I wish I could just check the model plate on the deck to obtain the Model/Serial number...the problem is, this engine is on a totally different LB deck. The engine is on an 8243AE deck.
About 15 years ago I had an old Lawnboy 8243AE (the key electric start one with no pull cord) I pulled the engine off and gave it away. I kept the 8243 Deck and put the 681430-D3 engine on it since the deck was in much better shape. Since the model number on the deck tag does not match with the old engine, can anyone tell me what year/model/series mower this engine went with? I went to Lawnboy.com and pulled up the part drawings, but I want to be 100% sure its the correct drawing so I can get the correct parts.
I have the engine ripped completely down to the rod and piston, I want to rebuild it. Can anyone point me in the right direction? Everything from piston, rings, seals, gaskets etc. I've wrenched on Lawnboys over the years, mostly carbs, exhaust port cleaning, and ignition pack. I'll be honest, this is the first engine I've ever opened up. The most depth I've gone into an engine is replacing the valve cover gasket on my car lol. I'm assuming the piston on this Lawn boy is toast, but i really have no idea.
This mower hasn't ran for a couple years now. Good spark, but won't sputter. Even with starting fluid in the carb or cylinder...nothing. I cleaned the carb, exhaust ports and even replaced the ignition pack. Nothing. I guess that's why i ripped it apart.
Any advice would be very appreciated.
Thanks guys!
Thanks guys!
