Lawnboy lawn mower
Ruralhdmechanic
Hey all
No nothin on lawn mowers
But my lawn mower doesn’t start fuel pumps out when I push primer
I can’t recall but I think this part had a clear bulb
Attached photo
I know it’s aTecumseh carb
what do I need to seal this back up
Hammermechanicman
The air cleaner attaches there. The priner should be a red bulb on the side of the carb. You need an air cleaner and the cover for it. It pushes on and twists.
Ruralhdmechanic
Fuel pumps into the air cleaner?
Cause when I prime fuel pumps out
Ruralhdmechanic
Also just looked I see the primer bulb is ripped and leaking so guess I start there
upupandaway
FYI: You press the primer to squirt some gas from the bowl below up into the air passage. When the motor is running, the vacuum of the air the engine is pulling in does this. So yes, when u press the primer you should expect to see a little gas come out. So long as u see gas come out, a torn primer is not so critical.
When u prime it and see gas come out, does it even run for a second then die?
Ruralhdmechanic
Replaced primer bulb
Now it will start and die right away
Assuming I need to clean the carb
