I need to know what champion spark plug to use. Thanks Steve
S sk734 Member Joined Aug 22, 2017 Threads 8 Messages 20 Oct 26, 2019 / Lawnboy 8430 #1 I need to know what champion spark plug to use. Thanks Steve
Scrubcadet10 Moderator Staff member Joined Sep 24, 2017 Threads 250 Messages 6,441 Oct 26, 2019 / Lawnboy 8430 #2 Parts diagram shows a RJ12C
V viperv10 Well-Known Member Joined Oct 7, 2016 Threads 45 Messages 171 Oct 27, 2019 / Lawnboy 8430 #3 Hello there, CJ14 can be used in that mower and in lot of lawn boys. The other one mentioned is about the same but is a resistor plug. Some areas require you to use resistor plugs but I live in the country and no one cares out here. Regards Jerrry
