Lawnboy 5126 Hard to start
RandyCanada
My old Lawnboy is really hard to start. Even priming the engine does not work all the time. Once is is started, it runs great. Any ideas?
plus, I can't find my model, model 5126 on the Lawnboy site to get a manual.
Thank you.
If my memory is still working, your 5126 unit is an F-series Lawn Boy. This manual should help you. I would start by removing the carb and give it a good cleaning. Don't forget the idle jet on the side. When reassembling, replace the float needle and seat. Part number 92-9697.
https://lookup3.toro.com/ttcGateway/acrobat/manuals/lball.html
LB8210
Replace the top and bottom crank seals. The old hardened seals leak and suck air, which leans out the mixture that shows up as hard starting a cold motor.
