the muffler is rotted right where the exhaust comes out of the bottom of the engine. should I cut a piece of tin and pop rivet it or JB weld it or body putty it in place? or i could use thin sheet metal as well. i could tack weld also but only have stick welder. it is a rectangler area about 1/2 X 2.
