Lawnboy 10686 leaking gas out of air breather
GTA_G20_
Hi guys I picked up this lawnboy and it’s in good shape. Needing a battery and key for the lecture start otherwise complete. It doesn’t start and I’m assuming that this might be a major issue
I cleaned the gas tank and fill with gas. Attempted to start without the filter on and gas is pouring almost directly out of the red breather tube. What is wrong and how can I fix this
tom3
I'd guess the float or the float needle valve inside the carb needs attention. A really small piece of something in that needle valve will cause the overfill.
GTA_G20_
Thanks. I’m going to tear it down and have a friend run it through an ultrasonic
tom3
Some of the newer carbs have a rubber insert in the recess for the float valve. If the needle has a metal tip look for that.
Fish
The engine is a Tecumseh, if you want to look for stuff on youtube on the carbs.
If the float is brass, shake it to see if there is fuel inside.
