Lawn mower issues
esmigarcia64
we have a snapper self propelled lawnmower model number 725EXi it’ll start and then it will turn off. We hadn’t started in a while but it was working fine before. Can someone gives us some advice on what to check so that we can get it going. Thank you so much
That is the Briggs engine series. Nothing to do with the Snapper mower. Just an FYI.
Old gas. Dump and flush out the fuel tank. Probably wouldn't hurt to install new fuel line while you are there.
Clean some cooling fins. Bet the upper shroud has never been off.
