I am in the midst of "attempting" a repair on the carb and parts for this mower that will not start. There is a thick layer of grease and grass over everything so I am trying to degrease and clean the plastic parts so I can actually see what I am looking at. Does anyone have a solution or grease remover method so I can soak the parts to remove the majority of grease?
Here is what I have tried :
1) Warm soapy water
2) Tooth brush
3) Air compressor
I am probably going to overhaul the carb at some point, but I need to get the rest cleaned first. Any suggestions?
1) Warm soapy water
2) Tooth brush
3) Air compressor
