Lawn Boy 8243
Asgar
Lawn Boy 8243 surges and stalls when choke is off, runs great with choke on, have cleaned card. What would cause this? Would a defective primer cause this?
FuzzyDriver
Just to add what Hammermec said, you're saying it's with the choke on...on all the way or slightly off full choke? If it's running great with the choke slightly off from full, then I have seen this issue with a bad governor spring.
