Lawn-Boy 5124 need help removing from deck
Lawn-Hog
hello i am new here to this forum i came across this lawn-boy 5124 push mower and i started to take it apart but i can seem to get it off the deck anyone got any ideas or a manual ?20200428_102659-1.jpg
Engine mounting bolts are probably under the muffler, which must be removed first.
dwross
Attached 1950-1988 Service Manual pdf file.
  • 1950-1988 Service Manual.pdf
AnthemBassMan
Yep. Pull the muffler off then there are three bolts holding the engine to the muffler plate. Then you can unbolt the muffler plate from the deck if you want it completely stripped down.
L8R,
Matt
