LA125 gas tank removal
heidi_alan
Has anyone ever removed the gas tank from a LA125? Does the entire floor assembly have to be removed???
Sort of.
All of this design tractor are the same .
The back of the guard is held down by the 2 spring bolts
The front is sandwiched between the frame & dash tower
All you have to do is loosen the dash tower bolts enough to get the back of the tower about 1" high
That will allow the guard to be raised just enough to wiggle the tanks out.
You will also need to remove one of the levers in he rear guard if they are fitted there
Most Deers will come out to the right .
Removing the actual seat will take a lot of weight off the guard which makes it easier to hold up.
When I do them I hook an engine crane to the back of the guard so I have two hands free to wiggle the tank .
