I tore into the unit today and I am in need of two bearings in the tranny. Both are located side by side on the main shaft and the same size, one has a snap ring around the outside to keep it from going in too far. The bearings are in a hundred pieces so I can't measure a size or get a number off. If anyone can find or would know the Kubota part numbers, I don't need a full breakdown.
